    Oct 2019
    Montana - 59771
    Default Water Heater TPR Valve Termination
    I was hoping to find suggestions on where to terminate a water heater TPR valve in an area subject to freezing and sub zero temperatures.
    Capistrano Beach, CA
    Default
    Thanks for posting here and welcome to InspectionNews!
    You will find a ton of information here but don't forget about the Member Benefits too.
    Some save you time, others save you money and some do both!
    Make sure you view the list of Member Benefits at: http://www.InspectionNews.net/home_i...MemberBenefits
    Sincerely,
    Brian Hannigan
    Twitter: @InspectionNews
    Default Re: Water Heater TPR Valve Termination
    Quote Originally Posted by Bob Risk View Post
    Unless the water heater is located on those temperatures (which is not a good idea anyway), the T&P is required to be terminated in the same space as the water heater is located.
