    Erwin, TN
    Default Flue Pipe on this Gas Water Heater
    I don't think this would be acceptable, because there is no 90 degree turn on the flue pipe coming up from the water heater ?
    Default Re: Flue Pipe on this Gas Water Heater
    Sam,
    I am unsure as to why you even used a question mark at the end of that sentence. I halfway believe that you posted this as an April Fools prank.
    Tape is not acceptable.
    Requires a fitting of some kind.
    Doesn't look like the single-walled flue pipe has screws.
    Looks like the large gas vent pipe is sloped the wrong way.
    No. Not acceptable.
    Cool Re: Flue Pipe on this Gas Water Heater
    Sam,
    No. Not acceptable.
    Agree all points as usual Gunnar. Also, if you look it up in the sizing charts at less than 3 feet vent rise, must be 4" vent connector. If this goes to a listed liner then wall shield ok. If not, need cleanout within 12" but then again, I've never found a heater flue that didn't need a liner.
    Arrgh! Bob, you always find at least one thing that I missed!
