Results 1 to 14 of 14
04-29-2020, 03:50 PM #1
What if home buyer and seller pay same inspector?
I am selling a rental property. The buyers paid their home inspector and then asked for four repairs. The repairs were correcting the low setting on a gas range burner so the flame would not go out, adding a GFCI kitchen outlet where one was not required, connecting an inoperative attic fan that never has had an electrical connection and, finally, turning on the angle stop to a toilet that needed a new flapper.
In their repair demand, the buyers asked that I pay for a return visit and report from their inspector. My wife and I fixed the range and toilet and offered to install a GFCI outlet or leave one for the buyers. We refused to do anything about the fan. I'm not willing to pay their inspector, partly because the inspection really isn't necessary.
Also because of this: Wouldn't it create a conflict of interest for the inspector to be paid by both buyer and seller in a single transaction? I'm sure most inspectors are honest, but I would not want to rely on a report paid for by a party who has an interest in exaggerating or minimizing things in which I should be interested. If you do see a conflict, is there a code of ethics or something that would make that clear?
Similar Threads:- Home Inspection for Seller: 2nd Opinion from Recent Home Inspection for the Buyer
- Seller don't know, buyer ?? Oil Furnace Age
- Homeowner Sues Seller And Home Inspector
- O'Fallon homeowner sues seller and home inspector - Madison County Record
- Buyer Tip: Get Home Warranty Funded by Seller - Realty Times
Last edited by Bob Hucker; 04-29-2020 at 03:57 PM. Reason: Can I move this to the Associations, Ethics... subforum? Maybe it fits better there?
04-29-2020, 05:12 PM #2
Re: What if home buyer and seller pay same inspector?
No conflict of interest when all is known and out in the open.
The key to your decision will be this: do you want to sell ... and ... are you willing to lose the sale over that?
It's a choice all sellers have to make.
04-29-2020, 05:22 PM #3
Bob,
In California, this is typically something that is negotiated between the buyer and seller through their agents. Personally, I don't like doing reinspections because so often, the repairs were done incorrectly. Then, I become the bad guy and no one likes me. I don't know about the conflict of interest. In Texas, I believe home inspectors are governed by the Texas Real Estate Commission. Maybe contact them to find out?
04-29-2020, 07:27 PM #4
Have you discussed this with your agent or whomever is representing your interests?the buyers asked that I pay for a return visit and report from their inspector
People can negotiate whatever they want (including you), so just because a request or demand was made, doesn't mean too much.
Off the cuff, it seems unreasonable that the seller would pay for a re-inspect on a list of negotiated repairs, but, who knows...
04-30-2020, 05:07 AM #5
Barry - what does the Texas IRC and Existing Building Code state regarding permits in Chapter 1 Administrative?
I haven't looked at the Texas codes to see what permits are required, and what is specifically exempt from having a permit (and, more specifically, not listed as exempt from permits) - and if it states something to the effect that work exempt from permits is not exempt from the code, that exempt work is still required to meet code.
Then what does Texas statute say about how reporting/not reporting unlicensed work effect a licensed person?
If it says what I suspect it may say, that could create a conundrum for a licensed Texas home inspector.
04-30-2020, 06:46 AM #6
What I was thinking of was, as Texas licensed people, if a Texas home inspector sees something that is likely/obviously/most likely 'work done without a permit', could (by statute and/or licensing requirements) the home inspector be disciplined by the state for not reporting the unpermitted work.
Which lead me to: what work requires permits?
Any Texas changes to Chapter 1 Administrative in the IRC?
Added with edit: see 105.1 Required and 105.2 Work exempt from permit.
Not much is exempt from permits.
Last edited by Jerry Peck; 04-30-2020 at 06:53 AM. Reason: Added IRC section numbers
04-30-2020, 07:12 AM #7
04-30-2020, 09:20 AM #8
It wasn't on the disclosure, because we didn't know the fan existed until now. We guess it was installed by a contractor who installed a roof for the previous owner, and the owner didn't want to pay for electrical work to connect it. It's in an attic that no one uses for storage, because there's another attic that is more spacious and easier to access.
04-30-2020, 03:54 PM #9
I've separated the items in the original post for easier reference as shown above.
The first item in the original list, adjusting the gas, should have been done be a gas contractor, but that's another issue: R105.2 Permits not required, 3rd item down, Gas, 2. (under Gas) - questionable for exempt from permit.
Second item in the original list, adding GFCI, R501.2 Permits not required, 2nd item down, Electrical, not exempt as it is not covered under items 1, 2, 3, 4, 5.
Third item on original list - same as above, not exempt per R501.2.
Fourth item in the original list, the angle stop, 5th item, Plumbing, not exempt as it's not within items 1 or 2 exemptions.
Not me, that's what the code states and why I referred you to those sections.
05-01-2020, 05:53 AM #10
That's what the tax asser does.
The building department helps stop people from killing themselves (and others).
And, yes, code inspectors don't look at a lot - if a code inspector were to look at a lot, permit fees would have to skyrocket to pay for it.
Also, yes, I'm quite dismayed that some code inspectors think it's a 'no brain required' job ... that usually comes from anove (building official), and that usually comes from above (city commissioners), and that usually comes re-election money (contractors who supply campaign funds complaining that inspectors "are to tough").
09-07-2020, 09:30 PM #11
In 14 years of inspecting I have never seen a buyer ask for the seller to pay for a re-inspection for repair items.
09-08-2020, 12:49 PM #12
There's a Dutch expression that says "You have NO already...". A buyer can ask for anything they want. As Jerry said - It's up to the seller (and sometimes the buyer) to decide if they want to lose the sale over it. Its up to the used house salespeople to negotiate the deal.
I don't really care who pays for the re-inspection. I do require a new contract to be signed however.
11-05-2020, 12:22 PM #13
It?s always a good idea to schedule a home inspection as early on in the sale process as possible so that there is plenty of time to negotiate and take care of requested repairs.
11-09-2020, 11:44 AM #14
