	06-22-2020, 11:42 AM #1 When required to replace seething? When required to replace seething?I had this show up in an inspection. The roof seething appears black due to a roof leak. At what point does the seething required to be replaced?
	06-22-2020, 05:00 PM #2 Re: When required to replace seething? Re: When required to replace seething?Did you poke at it with your finger, screw driver, or a probe? If so, what did you find?
	06-23-2020, 04:50 AM #3 Re: When required to replace seething? Re: When required to replace seething?What Jerry said!
 I would be seething too if I forgot to probe the sheathing for damage.
	06-23-2020, 06:56 AM #4 Re: When required to replace seething? Re: When required to replace seething?Curious as to what is on the roof at that spot, to the left of the vent stack - a chimney structure or similar?
 If so, the side of it may also be affected, as well as that truss top chord.
