Results 1 to 4 of 4
    Jul 2019
    VA
    Default Concrete block in the concrete pad in the basement
    Can anyone tell me what is the purposeblock in floor.jpg of putting a concrete block in the basement concrete pad? You can see the gravel below through the block opening. See attached image.
    Nampa, Idaho
    Smile Re: Concrete block in the concrete pad in the basement
    It's to let Radon gas into the home.
    Default Re: Concrete block in the concrete pad in the basement
    DIY safe rough-in...?
    Egbert Jager
    Diamond Home Inspection
    http://www.diamondhomeinspection.ca
    Usually its a rough in for a bath tub drain under there.
