Results 1 to 15 of 15
    Apr 2007
    WESTMINSTER CO
    Default STAIR STRINGER NOT ON LANDING
    Greeting all and Happy New Year
    Got a new build here and isn't the stringer suppose to sit fully on landing or be notched
    thanks
    charlie
    Apr 2007
    WESTMINSTER CO
    Default Re: STAIR STRINGER NOT ON LANDING
    thanks
    charlie
    LEFT OUT PICTURE
    Still no pic....
    Apr 2007
    WESTMINSTER CO
    Still no pic....
    still trying to upload photo
    Apr 2007
    WESTMINSTER CO
    Dom
    I cant get the picture to upload and im following all instruction--never had problem before. wish i could email it to you. need to get an answer before Monday
    charlie
    Charlie, the usual reason as of late (the past couple of years) is that the photo is larger than 1200 on any side.
    I suspect the reason it didn't used to be we weren't using camera settings which too higher resolution photos, and with higher resolution comes a larger size, and it blows past that 1200 limit.
    Apr 2007
    WESTMINSTER CO
    just made photo smaller here it goes
    Yep, heel of stringer bottom needs to rest on something, not just air.
    I suspect that they set and poured the landing pad based on rough measurements, then constructed the stair, and ... oops ... the run of the stair was shorter than they estimated it would be*.
    An extended concrete pad needs to be poured, and it needs to be doweled into the existing concrete pad so it will stay in place.
    *Which causes me to suspect that the stair treads and stair risers may not be consistent, and may not be correct either.
    Apr 2007
    WESTMINSTER CO
    thanks Jerry
    don't remember having to reduce photo that much in past. Here is say house and the deck post footing--again new build. Can't wait to send pictures to the city and see what they say about passing this job
    thanks
    charlie
    Charlie, The tops of those foundation pilings/footings (whichever they are, probably just footings) being chipped off may likely be of no structural consequence, just cosmetic, depending on:
    - is the column inside a metal column and fully supported on its base on the flat center top of that footing
    - is the column inside a wood post and fully ... blah, blah, blah
    - is the column inside a concrete block column and fully ... blah, blah, blah ... or does the concrete block column inside overhang the face shells being fully bedded and supported?
    However ... look at the off-plumb angle of that back colum (see photo).
    Apr 2007
    WESTMINSTER CO
    Thanks Jerry
    Yes did note the off center back post. But the buyer freaked out on the compromised concrete and so did I. For gosh sake its new, don't ya think when they saw the bad concrete they would have fixed it. Everything is a rush job today with these builders
    thanks
    Possibly hit the top of that with a Bobcat moving earth around leveling the area out. Doesn't take much of a hit with the bucket of a Bobcat to break those concrete corners off.
    Not that it really matters much, but I have seen concrete lose corners when the forms are stripped too soon as well. Concrete doesn't take much abuse when it's still green.
    I would guess that the column footings were made that massive in order to follow the visual lines of the columns above. While I do agree with Jerry that the damage to the piers is likely not structurally significant (within the parameters that JP set), I also agree with CVF that had they patched the concrete, it would not have been flagged as an issue. Now, the contractor is going to have to get something from the PE to verify that it isn't a problem.
    This is something that I keep thinking about:
    That not plumb column may have been hit by a Bobcat, which bumped the bottom sideways.
    IF that happened ... IF ... that happened, then the footing is likely not deep enough. The bottom of footings are supposed to be a minimum of 12" below frost depth, and frost depth is likely at least 2' to 3' down up there, which would mean that the bottom of the footing would be at least 3' to 4' down.
    If a Bobcat hit a concrete column foundation which was 2' to 3' tall, and 3' to 4' in the ground, I doubt the bottom would have moved. More likely the top would have tipped to the side. Which would leave the column looking "broken" at the top of the concrete to column joint.
    Last edited by Jerry Peck; 02-22-2023 at 06:00 PM. Reason: Posted using phone, just noticed a "for deep enough" where a "not deep enough" should be
