    Sep 2008
    so so, California
    Default gooey brown stuff leaking out
    Anyone ever seen this on EIFS stucco? Its this of the wall.
    - - - Updated - - -
    Sorry, not sure why the pics are doubled.
    Sep 2008
    so so, California
    Default Re: gooey brown stuff leaking out
    Oct 2014
    Am I seeing it right? It seems that you have a crack towards the top of the image; the crack widens going downward; and two brown streams trickled down from that?
    La$ Vega$, Nevada
    Saw something similar here in Las Vegas years ago. Did you taste or smell it? (Not trying to 'bee' funny here) Saw the same discolored liquid trail down an exterior stucco wall surface, following a stucco-crack. We traced it down to an abandoned honey-bee colony in the attic that left a large honey comb above the soffit. It only leaked when it got hot outside. It also left a small trail down a 2nd story bathroom window. The attic entry point was some distance from the honeycomb. Looked like honey...smelled like honey...tasted like honey. Was honey! Quite a mess to clean-up...but much preferable to other types of infestations we run into. Could not get to it from the attic. Clean-up crew to remove a lot of drywall in the bathroom to perform clean-up.
    Glenn R. Curtis CMI
    La$ Vega$, Nevada
    Inspecting Nevada since 1982
