Thread: SPF insulation
    Oklahoma City
    Default SPF insulation
    I don't see this stuff much at all and have a question. Does this spray foam insulation blown onto the underside of the roof framing require a fire retardant coating be sprayed over it?
    And no, that is not a flue, it is a fresh air intake for the ventilation system.
    If it weren't for lawyers, we would never need them.
    Default Re: SPF insulation
    Quote Originally Posted by Frank Bombardiere View Post
    .No..
    .No..
    Ok, waiting for the other shoe to drop.
    When all JP has to say is "No", you have to wonder.
    Hey, I just realized what the three dots are for - minimum 5 characters!
    Anyway, this has been discussed fairly recently - if you search the forum for "attic foam insulation" without the quotes, I think you'll find some useful info.
    .Yep.
    I figured that this was old by now:
    Charlie Chaplain
    Buster Keaton
    Lucille Ball
    Stan Laurel
    Oliver Hardy
    Darrel Hood's Avatar
    Darrel Hood Guest
    I know this an old thread and I am a new guy to this forum. However, the correct answer is "probably no". Based on fire safety testing a few brands require the barrier.
    Darrel,
    Would you give us those brands and the code section which applies to that requirement?
    Thanks.
