    Eric Shuman's Avatar
    Eric Shuman Guest
    Default Unconventional ridge/valley
    The instersection of the ridge/valley at this roof makes me a bit nervous. Seems like water could get under those ridge shingles fairly easily with the right stituation in play.
    Any thoughts?
    Thanks,
    Eric
    Default Re: Unconventional ridge/valley
    For starters, it's hard to tell in the picture, but are all those roof planes 4/12 or greater?
    In any case I sure hope there is waterproof shingle underlayment under there all the way down from the ridge at that right hand valley, because I share your suspicion that water is going be driven up under the edges of the shingles to the left. Also looks to me (would like to see a picture from below) like that detailing at the bottom of the left hand valley is likely a problem as well.
    Healdsburg, CA
    Whoever designed that roof configuration should have their pencils, slide rule and drafting paper removed from their possession as it is "BUTT UGLY!" Properly installed underlayment will probably keep the house dry, but then again who knows?
    The Shadow may
    Jerry McCarthy
    Rod Aparicio's Avatar
    Rod Aparicio Guest
    Guys,
    Is it me or do I notice a small indentation/sag on the roof? Look at bottom right hand corner of the photo....just off of that at about a 45 degree angle. Do you guys see that? How was the roof over all Eric?
    Thanks!
    Rod,
    Yes, it does look like that, doesn't it.
    Definitely going to leak, especially with snow and thaw cycles. The shingles should have been continued through the valley up to the ridge creating a typical lap joint, not cut as it appears in the photo. Unless they have a continuous ice/water shield running through the valley to the ridge it won't last. Depending on what kind of inspection you are doing, consider giving client info on roofing procedure options and checking warranty paperwork. If you lift shingles (carefully) at gutter line you can sometimes determine if they put down ice/water shield or just #15 felt.
    Aug 2009
    Michigan
    Quote Originally Posted by Rod Aparicio View Post
    Guys,
    Thanks!
    Is that a sag or yet another change in the pitch. Looks to me like the pitch increases there and the lower level has a less steep pitch.
    Randy Gordon, construction
    Aug 2009
    Michigan
    The Shadow may
    My guess, someone who is qualified didn't design this!
