Thread: Siding question
    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Default Re: Siding question
    "Upper siding is hardiplank. Bottom of hardiplank rests on a wood ledge that is sloped nicely. The wood ledge rests on top of the lower, stone siding wiith caulk between the interface joint."
    "1- Is the hardiplank be at least an 1/8 inch from the wood ledge?"
    I believe it requires a 1/4" space below the Hardieplank.
    "2- Is a flashing cap required between the wood ledge and the stone?"
    Is the stone adhered veneer or installed with an air space like regular brick veneer?
    If adhered veneer, it would be a good idea, but not sure that it would be "required".
    If installed as 'masonry veneer' (like brick veneer), then, yes, it would need a through wall flashing (in this case, a cap flashing) attached to the wall and turned up the wall, extending out and across the air space, extend to the edge of the stone, or to within 1/2" of the edge of the stone (with the intent being to drain/weep all the water from above out and over the masonry veneer).
    Mike Huppi's Avatar
    Mike Huppi Guest
    Smile Re: Siding question
    Look at this and see if this answers your question. If not email me and I will send you the Hardi Trim installation guide it is too big for me to load on here.
    Attached Files Attached Files
    Mike Huppi's Avatar
    Mike Huppi Guest
    Thats the one thanks
    I see this stuff installed wrong every day. I called out the clearance and flashing needed around penetrations on two different homes today.
    Martin lehman's Avatar
    Martin lehman Guest
    I realize these installation instructions are for James Hardie siding, but are the majority of manufacured siding installations basically the same as these?? As far as fastening requirements, not using staples, caulking of joints, clearances, etc.??
    What is your experiance?
    BTW, I always recommend siding maintain 4" clearance above hardscape, not 2". Is the 4" requirement only for wood??
    Will Handley's Avatar
    Will Handley Guest
    Quote Originally Posted by Martin lehman View Post
    I believe the deflection requirements are 4" from grade and 2" from paved or covered grade surfaces, ie; flat work.
    I call it out on anything than can be damaged by water/moisture conditions.
