    mathew stouffer's Avatar
    mathew stouffer Guest
    Default shear wall inspection
    I am training to become a home inspection and need some info on shear wall inspections. Any broad inspection techniques you want to offer.
    Healdsburg, CA
    Default Re: shear wall inspection
    Pick up some Simpson Catalogs on shear wall bracing. Also, I’d Google foundation shear wall bracing as there’s loads of info on the internet such as; Earthquake Retrofitting, Foundation Bolting and Cripple Wall Bracing | Earthquake Safety.
    Jerry McCarthy
    Jerry Mc.
    Pretty good website. Good basic information. I particularly liked the rusty bolt segment.
    Aaron Miller's Avatar
    Aaron Miller Guest
    Mathew:
    Shear wall or braced line wall construction is often specifically engineered for a project. When it is, refer to the construction documents for the engineer's recommendations. Otherwise refer to IRC R602.10.
    See:
    http://www.kitsapgov.com/dcd/brochures/62.pdf
    http://www.strongtie.com/ftp/bulleti...ALLBRC06-R.pdf
    http://www.strongtie.com/ftp/catalogs/C-SW07/C-SW07.pdf
    http://www.co.henrico.va.us/bldg/pdf...WallPanels.pdf
    http://www.bssconline.org/Homebuilde...pter5final.pdf
    Aaron
    Thanks for your help, the information was very useful.
