    william siegel's Avatar
    william siegel Guest
    Default corrosion around threads
    This is a three year old heat pump unit in a condo. What would cause the corrsion around the water connections.
    Sorry about the poor quallity picture.
    Default Re: corrosion around threads
    Condensation building up on the uninsulated section of the suction line in cooling mode.
    Colorado Springs, CO
    Talking Re: corrosion around threads
    The new message board is less than 3 weeks old and we already have corrosion around the threads! What is the world coming to?
    Bruce Breedlove
    www.avaloninspection.com
    Except those are not refrigerant lines, those are chiller lines.
    There is/was/has been leakage there, most likely at the top joint.
    Looks like 'newer' pipe thread tape.
    Probably 'was' leaking.
    Tim Moreira's Avatar
    Tim Moreira Guest
    What's the odds on an electrolysis problem???
    Just a thought.
    What were the materials???
    Quote Originally Posted by Tim Moreira View Post
    Just a thought.
    Water ... running down ... metal ... equals ... rust.
    Tim Moreira Guest
    I was questioning the green stuff next to the Teflon tape at the top fitting???
    "Looks like 'newer' pipe thread tape."
    Man, I have got to get some new glasses. Jerry - what kind do you use?
