Thread: bird blocking?
    Jerome W. Young's Avatar
    Jerome W. Young Guest
    Default bird blocking?
    This is a dry system, front of tile at eaves fastened with clips; backs nailed to ledger boards over felt; fancy tile roof about 18 yrs old. I call it bird blocking but it probably has a more technical name. There was none installed here. What can I say about it? Problem?
    Default Re: bird blocking?
    Aviary Retention System sounds good.
    rick
    There are three terms, used mostly interchangeably:
    - Bird stop
    - Eave closure strip
    - Eave riser strip
    The last two are frequently used as: eave riser / eave closure strip.
    Healdsburg, CA
    Bird Abuse
    Jerry McCarthy
    Jon Randolph's Avatar
    Jon Randolph Guest
    Bird Abuse
    Jerry, are you calling a fowl?
    David Banks's Avatar
    David Banks Guest
    Are you guys just winging it?
    Quote Originally Posted by Jon Randolph View Post
    Unnecessary roughness, feathers were ruffled and flying, 15 yards (no TP).
