    Jim McClendon's Avatar
    Jim McClendon Guest
    Default P trap to waste pipe?
    Is a p trap to waste pipe allowed for ac condensation?
    Default Re: P trap to waste pipe?
    During non seasonal use what keeps the trapped primed? If trap dries out sewer gases in the attic.
    Cheers,
    Quote Originally Posted by Jim McClendon View Post
    Jim,
    Generally, you will see a drain pipe connected to the p-trap under a bathroom sink. Like Raymond indicated, a trap primer would be necessary in this case.
    Aaron Miller's Avatar
    Aaron Miller Guest
    Jim:
    It's just plain wrong.
    http://www.inspectionnews.net/home_i...html#post16917
    Aaron
    Two mentions of a trap primer, none of the missing air gap ...
    ... unless you read through the posts in the link Aaron posted.
    Jim McClendon Guest
    Thanks all, and thanks for the diagrams.
