Results 1 to 2 of 2
Thread: Split Busbar
    Jim Makara's Avatar
    Jim Makara Guest
    Default Split Busbar
    I know that no more than 6 disconnects can be used to turn off all of the electric in a home.
    Hower what I don't know is if the amount of the total breaker amperage of the 6 breakers can exceed the the amount of the service cable.
    Today I saw a split busbar with at total of 350 amps of the 6 main breakers.
    A 200amp service wire with no main disconnect from the meter was observed.
    Thanks to all who can help me with this dilema.
    Default Re: Split Busbar
    Hey Jim - Long time no post!
    Just the fact that those breakers add up to 350 with a 200 SEC isn't a problem. There isn't any magic formula.
