03-24-2008, 04:40 PM #1
FOAM BOARD / STUCCO OVER RESIDENTIAL SIDING
I dont know much about this type application. Is there a requirement for plywood/OSB on the exterior walls in florida? This house is the first I have have seen. The stucco wire lath was rusting in several areas along the bottom and has cracked the stucco etc. I can feel the foam when I reach ndeer the bottom edge. Should this be wrapped or filled with something?
03-24-2008, 06:06 PM #2
Re: FOAM BOARD / STUCCO OVER RESIDENTIAL SIDING
EIFS
(Exterior Insulation Finish System)
YECH!
03-25-2008, 03:27 AM #3
Jerome:Should this be wrapped or filled with something?
It should be wrapped with laborers removing it and the void filled with a viable cladding material. Espceially in Florida . . .
Aaron
03-25-2008, 04:45 AM #4
Thats what i figured. Thanks
