    Default Help needed with ID of receptacle
    What is the intended polarity/voltage of the lower receptacles?
    And what would likely have been drawing current from these - there is one on an enclosed front porch, and another behind in on the interior of the exterior front wall.
    Default Re: Help needed with ID of receptacle
    The closest configuration I could find is a 208 volt 30 amp, but that would not be on duplex, it would be a single receptacle.
    Sooooo ... got me.
    Tim Moreira's Avatar
    Tim Moreira Guest
    Wow,
    Never saw that before.
    208v would be three phase. *Could be* but *not likely* on a residential home.
    May be some kind of recreational outlet????
    Over at Mike Holt they pointed me here:
    ECN Electrical Forums: 4 Prong Duplex Receptacle
    Appears that this is designed to accept either a 120 or 240 15A ungrounded plug.
    I'm still wondering what might have been plugged into it.
    Very interesting.
    Thanks for the info.
