Results 1 to 4 of 4
    j.Peter Buss's Avatar
    j.Peter Buss Guest
    Default Undersized wire !
    j.Peter Buss vbmenu_register("postmenu_37318", true);
    Member
    Re: Check out these undersized wires !
    Hi, Check this out,
    This is from an inspection i performed today in chicago, people were living in the house with this condition for some time - Main drop entrance cable (Hot & Neutral) in service panel spliced with a # 14 wires to the 100 amp main breaker and neutral bar - Wow !! The drop cable was not long enough at installation so this is how he/she repaired the issue.
    Peter Buss
    Buss Inspection Services, Inc
    Buss Inspection Services, Inc.
    David Banks's Avatar
    David Banks Guest
    Default Re: Undersized wire !
    Nasty!
    Will somebody please send Mr. Buss a kewpie doll?! That's a prize winner!
    That would be called a "fusable link". When the current exceeds the ability of the wire to carry it, the wire melts and shuts down the circuit(s). It is all contained in a metal box, so what's the problem?
