    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Any suggestions on this!
    I came across this on an inspection today. It seems a little "make shift". The house was huge, 9000 sp feet, so it was difficult to tell what was above the area once I got turned around in the crawl space. However, it appeared to be a stone fireplace. Despite the apparent failure of the 2x6, what was going on here.
    Ron Bibler's Avatar
    Ron Bibler Guest
    Default Re: Any suggestions on this!
    Thats a good one. a bit of overload for a 2x6 plate.
    Ron was hear.
    Richard Moore's Avatar
    Richard Moore Guest
    Mathew, without knowing what is above it seems we have two choices.
    A: It's a purely decorative lump of wood meant to beautify the crawl.
    B: It's a necessary structural support post that lacks an appropriate footing because someone didn't read the plans, and is in need of repair.
    My money would be on B.
    Aaron Miller's Avatar
    Aaron Miller Guest
    Mathew:
    I've seen similar things and usually suggest that they have an engineer specify the addition of a steel angle or the like at the edge of the concrete to support this mess.
    Aaron
    Patrick Norton's Avatar
    Patrick Norton Guest
    I'd say it needs fixin!
    Thanks guys. Have a great day.
