Results 1 to 4 of 4
    Michael Vasquez's Avatar
    Michael Vasquez Guest
    Default Stranded conductor split under two terminal screws?
    I came across a stranded conductor (large diameter) on the bus bar with the strands split under two terminal screws. I have never seen this before. Does anyone have any information on this?
    Thank You
    Default Re: Stranded conductor split under two terminal screws?
    I've seen it a few times. It's not right, of course. Should terminate on a single properly sized lug.
    Thanks. It didn't look right and just wanted to be sure before I reported on it.
    Previous thread:
    Grounding conductor split to fit into two lugs??? - Home Inspection & Home Inspector Services For Inspections and Inspectors
    It frightened me when you accepted my word for it. At least the old thread has the JP stamp on it.
