    Ron Bishop's Avatar
    Ron Bishop Guest
    Default mystery siding...
    I have not seen this type of exterior siding before. It appears to be a 4x8 sheet, with small pebbles attached to it. Cany anyone help me identify this material?
    Thanks you
    Default Re: mystery siding...
    Looks like a commercial concrete building panel.
    Michael P. O'Handley's Avatar
    Michael P. O'Handley Guest
    Hi,
    Are you quite certain it's in 4 by 8 sheets? I see something similar sometimes but it's just a 3-coat stucco with a final finish that contains aggregates.
    OT - OF!!!
    M.
    Ron Bishop's Avatar
    Ron Bishop Guest
    I was thinking that it may be 1 coat stucco as well. The sheets go directly into the ground, however, and no weep screed is present.
    Ron Bishop's Avatar
    Ron Bishop Guest
    oops...3 coat stucco
    Ingleside Illinois
    I saw the same type product in January and asked the same question. The siding on the place inspected was howver something the contractor fabricated on site, it was coming apart everywhere. It was stucco over 4x8 plywwod with stones added for eye candy.
    Ron Bishop's Avatar
    Ron Bishop Guest
    interesting...thank you
