Results 1 to 23 of 23
Thread: editing
    Default editing
    A problem just started happening today ...
    When I click on 'Edit', I get an error message, I click 'OK' and my Microsoft Internet Explorer browser closes.
    Default Re: editing
    Let's see what happens when I try it with firefox...
    no problemo
    Last edited by John Arnold; 04-25-2007 at 08:48 AM. Reason: testing editing button
    Default Re: editing
    Edit test
    Worked for me too.
    Last edited by Rick Hurst; 04-25-2007 at 08:56 AM. Reason: verifying edit function
    Capistrano Beach, CA
    Default Re: editing
    I was in the middle of editing Jerry's message (as a test) and the neighborhood lost powere. Jerry, I thought you said just your browser crashed, not the local grid. This reply is from my phone. I guess this is when I catch up on paperwork.I am now editing this from my phone. So far no problems.Jerry, look into your system.
    Sincerely,
    Brian Hannigan
    Twitter: @InspectionNews
    Tim Moreira's Avatar
    Tim Moreira Guest
    Default Re: editing
    Brian,
    I get the same message/problem as Jerry when I went to edit one of my posts.
    I thought it was me, I've been having computer problems myself, but after rebooting and tring again and agian I get the same message and internet explorer closes out to my desk top.
    BTW, is there a mute button for Megan?
    Default Re: editing
    Sounds like you may have two issues.
    1) Editing
    2) Megan. Megan will only play once per session. Are you seeing her on every page you go to? You should see her once and that is all until you close your browser and return or return after a long time away.
    Let me know.
    .... Just came back in to edit (to test). No problem.
    Sincerely,
    Brian Hannigan
    Tim Moreira Guest
    Default Re: editing
    Editing is the problem. When I click on it I get the same error message as Jerry and then the Internet Browser closes leaving me back to the dest top.
    Megan was just getting annoying after rebooting several time and getting back to this thread.
    Tim Moreira Guest
    Default Re: editing
    test.
    Well, it works on my laptop but not my desk top. That's weird and going to be a real pain for the future it it stays this way.
    Default Re: editing
    Anyone else having an issue when they click on "edit"?
    Please let me know.
    Sincerely,
    Brian Hannigan
    Default Re: editing
    My 'Edit' problems just started today or late last night, but it was working before that.
    Nothing on my computer has (to my knowledge) changed.
    Yeah, Megan is another problem - can you give a way to make her not appear if we do not want her? Please.
    Bob White's Avatar
    Bob White Guest
    Default Re: editing
    I just went back to the "Megan" thread to test edit (twice) ...
    Hit the edit button, and IE errored out and shut down...
    It looks like the edit works this time....
    Last edited by Bob White; 04-26-2007 at 05:43 AM. Reason: testing the edit function
    Default Re: editing
    I just test did a test edit on Rick's snake story and had no problems.
    Using IE
    Jim
    Default Re: editing
    Those having trouble editing please try now and let me know.
    Also let me know if the issue is when you click the "edit" button or the "Advanced Edit" button.
    Sincerely,
    Brian Hannigan
    Default Re: editing
    My problem is when I click "Edit", I have no chance to get to "Advanced Edit".
    My problem also started about (maybe it was) the same time as Megan started.
    While you are at it, Brian, and if you would, when in Edit mode (at least when I used to be able to get there), it would be helpful if the photo links still appeared in the posts.
    Sometimes I would need to view the photos again, but had to post, then view the photos, then go back and edit my post. It was the same on the old board, but this board is more advanced, so maybe you can do that?
    "Advanced Edit" is (was - can't get to it now) nice because, while "Edit" did not allow you to add photos or files, "Advanced Edit" did.
    Thumbs up Re: editing
    OK, those of you that had an error editing please try again and let me know if it has been corrected.
    Jerry, when editing you have full control over your photos.
    What you need to do is go into the edit "Go Advanced" mode and then scroll down below the text box to the "upload photos" area. The same place as when you are uploading photos. Click on "Upload Photo". In there you will find links to your photos ("Current Attachments") in that post and to the right of the photos is a "Remove" button. You can remove photos and/or upload more.
    Sincerely,
    Brian Hannigan
    Tim Moreira Guest
    Default Re: editing
    test...
    OK it is working now.
    Thanks Brian.
    Default Re: editing
    Great! Glad to hear we are back on track.
    Jerry, is yours working too?
    Sincerely,
    Brian Hannigan
    Default Re: editing
    Hey Tim,
    How about now?
    Sincerely,
    Brian Hannigan
    Bob White's Avatar
    Bob White Guest
    Default Re: editing
    'Edit' worked for me this morning.
    Default Re: editing
    I've been afraid to try it but here goes.
    If it works, I will add a line below this line, if not line is below ... well, that means it did not work.
    Guess what, there is now a line here. Now I'm going to try the Go Advanced.
    Go Advanced worked too.
    Thanks Brian.
    Now, on this Megan thing ...
    You need to edit your post from "well, that means it did not work." to "well, that means it did work."
    Megan is working part time now.
    Sincerely,
    Brian Hannigan
    Tim Moreira Guest
    Default Re: editing
    test, test, test
    Yepper, it works now.
    Thank you.
    Default Re: editing
    Quote Originally Posted by Brian Hannigan View Post
    No, I had/have it correct, read that sentence again.
    "If it works, I will add a line below this line, if not line is below ... well, that means it did not work."
    I should, though, go back and edit the "if not line' to "if no line".
