Results 1 to 13 of 13
Thread: Porch
    Sep 2007
    San Antonio TX
    Default Porch
    edited
    David Banks's Avatar
    David Banks Guest
    Default Re: Porch
    Any other pics? Is that a walking surface above? If so it should be built like a Deck with all the attachment details you would call for a deck.
    Sep 2007
    San Antonio TX
    Default Re: Porch
    edited
    Sep 2007
    San Antonio TX
    Default Re: Porch
    edited
    David Banks Guest
    Default Re: Porch
    Now that's a thread drift!
    Default Re: Porch
    Mabey thats Brain matter!
    Default Re: Porch
    OH yeah, it's not a Porch and it's not installed properly. LAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGBOLTS and HHHHHHHHHHHHHHHHAAAAAAAAAAAAAAAAAAAAAAAANGERS
    Default Re: Porch
    Quote Originally Posted by Zibby Swieca View Post
    How would write this up? Air does not leak but it creates moisture.
    That is one scary photo.
    Mustang
    Talking Re: Porch
    That is just a lattice cover it does not have to support anything but the lattice, so I see nothing wrong with toe nailed braces. I doubt any one can find a code that states other wise. The posts saying other wise is just opinions in my opinion.
    Default Re: Porch
    Zibby, I believe that "deck" which looks like a roof is called a pergola.
    As for the air handler "corrosion noted on exterior cabinet of air handler beneath suction line". If it doesn't seem to be causing any other type of problems, I don't know what else can be said about it. The corrosion appears to be the result of likely condensate leaks off the suction line. If it leaks and it is wet, it needs servicing.
    Default Re: Porch
    Quote Originally Posted by Tony Mount View Post
    Tony makes a good point. I wouldn't have a problem if they used thumbtacks to secure the joists. In fact, I just saw a house this week where I advised my buyers that the front porch roof shingles were secured down with the wrong flavor of bubblegum and that they didn't use enough paperclips on the roof decking.
    Default Re: Porch
    I agree since that there isn't much besides plant load, I wouldn't be too concerned about joist hangers.
    However, I would call for bolts into the wall through the ledger board to hold the whole thing up.
    Default Re: Porch
    I agree since that there isn't much besides plant load, I wouldn't be too concerned about joist hangers....
    I've seen some well developed wisteria vines that could put significant stress on something like that.
