    Eric Laney's Avatar
    Eric Laney Guest
    Default Today's widowmaker
    Honey did you turn off the power before changing the breaker?
    Eric Laney's Avatar
    Eric Laney Guest
    Default Re: Today's widowmaker
    To clarify the picture, in case it isn't obvious, the metal bracket that pulls the contacts out has come loose at the rivet. So, not only does the power not shut off, but the metal bracket swings into the main fuse while your hand is touching the arm. Pretty nifty huh?
    David Banks's Avatar
    David Banks Guest
    So why is your hand touching the arm?
    but... But...BUT... the asbestos siding is gonna' kill you anyway.... I read all about it on the Internets !
    Very good illustration of why the panel is supposed to be bonded.
    Eric Shuman's Avatar
    Eric Shuman Guest
    Great photo Eric, and another good example of why we ought to get paid more than we do.
    Eric
    Peter Plein's Avatar
    Peter Plein Guest
    I found the same thing. Other electrical problems in there too.
