    Kendall Goad's Avatar
    Kendall Goad Guest
    Default Swimming Pool Certifications
    This may be a crazy question.
    But, are there any special certifications required for inspecting swimming pools?
    I have had a few request for them but am not sure if my HI cert will cover it.
    Thanks for any and all responses.
    Kendall
    Default Re: Swimming Pool Certifications
    Quote Originally Posted by Kendall Goad View Post
    Kendall
    Well, my first question to you would be do you know anything about swimming pools?
    Home Inspector Certifications don't mean diddly squat, all of the ones we have now are done by the various membership associations to promote their own members. Pay your fee and you are certified!
    To inspect pools you need to know about them. How they are built and the different types of pools. You need to know about the special electrical requirements that pools have. The list goes on and on.
    If it was me I would find a good pool contractor and defer all pool inspection request to them. Then ask if you can tag along and shadow their inspection.
    To answer your question; No you do not need a special certification, just the knowledge and skill set.
    Kendall Goad Guest
    Thanks for the response Scott.
    I do have a pretty good knowledge of pools and there operation and a little knowledge on installation.
    I also like your advice on tagging along with a contractor. Great ideal.
    Thanks again,
    Kendall
    Garland, TX
    Certification may depend on your state and the services you offer.
    As far as I know inspection of residential pools are completed to State or Association SOP
    Commercial, where you issue a Certified Inspection so the operator can open their doors for business is a very different story.
    NSPF is probably the most recognized
    Check with your state or AHJ
    I work with a pool contractor who checks for leaks on pools with a pressure test on the lines. In my opinion it is like referring to any other specialist if needed. He also gives his professional opinion on the other parts of the pool. I have helped him install pools plus have had a pool for over 20 years but a through pool inspection is outside the scope of a normal HI.
