Thread: Cracks in wall
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Cracks in wall
    Just curious what you would report about a small step crack in drywall. The crack ran from one corner of the wall, across the wall to the kitchen cabinets. It was about 1/16 of an inch and had one large step. It is very difficult to recognize in the photo. Major settlement issues with the driveway slab is why I ask.
    Default Re: Cracks in wall
    You need to look at doors, windows, trim molding, etc., just one crack does not usually mean very much, but you need to take other signs into consideration.
    There was one other crack, however doors, windows were fine.
    Justin Watts's Avatar
    Justin Watts Guest
    I agree, check all the doors and windows, open and close them.... What kind of foundation is it? Any defects, upgrades needed, etc.? You need to evaluate the totality of defects...to make a better determination.
    Also, don't forget the "soil" ....... You may want to advise your clients to get a soils report or geo-technical evaluation
    Just make sure to let your client know that you are not a structural engineer, you do not do soils evaluations, etc. Cracks happen in surfaces, and all structures have some degree of movement that causes cracks.
    Hope this helps,
    Justin
    Orange County Home Inspectors, Certified Home Inspector, property inspectors, Huntington Beach Home Inspection, Laguna Beach and Santa Margarita Home Inspection Services
    Looks like a failure of the top and edge seams on a sheet of drywall. What is the cause of the circular dark spot at the corner of the crack?
    Lee Nettnin's Avatar
    Lee Nettnin Guest
    Looking at Michael's enhanced photo, I was thinking that this could be an archway or doorway that was patched over and closed off. Were the same cracks present on the other side of the wall? or if it's an outside wall can you tell if the siding was patched?
    Lee
    Richard Rushing's Avatar
    Richard Rushing Guest
    My top 10 to consider:
    1) As stated, interior cracks above/ below windows and at the top corners of doors.
    2) Flooring being uneven, cracked tiles, buckled wood planks, etc...
    3) Exterior brick cracks from window corners (top/ bottom)
    4) Exterior cracks where expansion joints are or should have been.
    5) Fascia board corner trim separation
    6) Ridge board-- separation of rafters
    7) Hip jack rafters should be checked for separation
    8) Fogged windows
    9) Trees too close to the foundation-- evidence of roots causing upheaval
    10) Improper grading and drainage (all encompasing of soils, guttering, high soils, low soils, dehydrated soils, areas of ponding water, etc...)
    Richard
