Results 1 to 2 of 2
    imported_John Smith's Avatar
    imported_John Smith Guest
    Default Gas Appliances In Fireplaces - Code Check
    Im waiting on my new Code Check to arrive, but came across a reference in my older Code Check "Maintain open vent (block damper in open position)", referencing IRC 2432.1. I couldnt find the reference in my IRC book for this requirement under 2432.1.
    Am I missing something, or has this been discontinued in the newer versions of Code Check?
    Thanks for any info you can offer.
    Exclamation Re: Gas Appliances In Fireplaces - Code Check
    G2453 Chimney Damper Opening Area. For unlisted decorative appliances, see Table G24553.1 (634.1)
    For listed appliances, see the listed instructions, as usual.
    HTH,
    Bob
