    Default Flippers Getting Lazier Every Day
    This house had a powder room installed right next to the bathroom in what looks to have been a linen closet. They didn't even bother to run the vent pipes to the exterior.
    Pic #1 is a little hard to see but it shows a view of the vent pipe right next to the attic hatch with the sink directly below.
    Pic #2 faintly shows the tail piece for the sink drain line sleeved into the vent stack. You could see water running into the pipe with the sink running.
    Pic #3 is the vent stack for the toilet.
    Just to show you some more plumbing prowess displayed in this house, pic #4 is of the drain lines beneath the bathroom in the basement. And three of the five sink drain lines in the house leaked when tested.
    South-West Michigan
    Thumbs down Re: Flippers Getting Lazier Every Day
    What ever happened to permits and code inspections ...
    Randall Aldering GHI BAOM MSM
    Housesmithe Inspection
    www.housesmithe.com
    Default Re: Flippers Getting Lazier Every Day
    I took the liberty of enhancing those a bit:
    Joshua Hardesty's Avatar
    Joshua Hardesty Guest
    I came across a house once that was done like that because they were hiding the fact they were doing any renovations. They didn't want holes in the roof to give it away to inspectors driving by.
    Quote Originally Posted by Randy Aldering View Post
    daniel nantell's Avatar
    daniel nantell Guest
    I heard a flipper tell one of his drywall people to seal the attic scuddle hole so no one can get in the attic to inspect anything. ????????
