    Jerome W. Young's Avatar
    Jerome W. Young Guest
    Default burst resistant hoses at heater
    Is this a problem?
    Default Re: burst resistant hoses at heater
    To my knowledge, yes.
    They should have used that flexible copper there ... allow me to correct that statement ...
    They "should have" done it with copper tube and fittings, 'as an alternative' they "could have" used those flexible copper lines there.
    "Should have" is on thing, "could have" is another thing. They chose neither.
    David Banks's Avatar
    David Banks Guest
    Do not see a vacuum relief either.
    Apr 2008
    McKinney Texas
    I think it may actually not be a problem. I was looking at some of that braided pipe today and I think it may be listed for water heaters, though not used as often as copper. Better double check but I may be right.
    Gene
    Randy Clayton's Avatar
    Randy Clayton Guest
    this type piping in my opinon is the best type tough not cheap is the best way to go the price is why you generally do not see it..
    When I was working on drag race carrs that was all we where useing
    Apr 2008
    McKinney Texas
    According to this plumbing supply house, they are listed for water heaters. Look here --> Stainless steel flex connectors - PlumbingSupply.com
    Jul 2007
    SpringHill Tennessee
    Gene South According to this plumbing supply house, they are listed for water heaters. Look here --> Stainless steel flex connectors - PlumbingSupply.com
    __________________________________________________ __________________________________________________ __________________________________________________ _________________________________
    I may be missing something, but I cannot find "Burst Resistant" lines that are rated for hot water heaters on this linked site. The picture that that Jerome posted appears to show what the website calls "Deluxe Braided Stainless Steel".
    Jul 2007
    Thumbs up Re: burst resistant hoses at heater
    I was not shouting on my previous post. I have forgotten how to do that quote another post thing and also I copied the actual font and size from the website. Sorry, Gene.
    Michael Larson's Avatar
    Michael Larson Guest
    Quote Originally Posted by Don Emerson View Post
    Here is the format Don.
    (left bracket)quote(right bracket)...........text....................... (left bracket)/quote(right bracket)
    Or you can use the "QUOTE" button at the bottom of the post.
    New Mexico
    I was walking through Home D today, and saw some water heater supply hoses. I checked the label to see who made them. None other than Watts.
    Watts: CWH-S | Flexible Connectors | Water Safety & Flow Control
    They seem to be fine for this type of installation from what I can tell.
