Results 1 to 19 of 19
    Tampa, Fl
    Default What type of roof is this?
    What type of roof surface is this. I am thinking PVC???
    Richard Moore's Avatar
    Richard Moore Guest
    Default Re: What type of roof is this?
    Looks like EPDM or Thermoplastic. Take a look at the Firestone site.
    Firestone Building Products U.S. - TPO Roofing Systems
    I'm guessing it is TPO.
    They do make EPDM with a white top layer, however, most EPDM is black.
    I haven't seen PVC used for roofing in over 15 years, but they may still use it (although EPDM replaced most of the PVC, and TPO is replacing most of the EPDM).
    Copper and coil thieves would be busy all night on that roof.
    New Mexico
    All the EPDM out here is white, for obvious reasons. I've got it on my rental property, and there are quite a few around town. A black roof here would be a nightmare. I haven't heard of TPO. What's that stand for?
    TPO stands for Thermoplastic Olefin or Polyolefin
    rick
    New Mexico
    Does the TPO look just like the EPDM, or is there a way to tell them apart. Just in case I run into it one of these days.
    EPDM is stamped with the manufacturer and the thickness along the edges of the roll (and sometimes in the center field areas) as I recall. EPDM is 'usually' always black.
    TPO is harder to identify as the labeling disappears into the white color (all TPO I've seen is white, some is white through and through, some is black underneath and white on top).
    Cary Seidner's Avatar
    Cary Seidner Guest
    It's TPO. You can tell by the heat welded penetration flashings.
    New Mexico
    The membranes here in my town were put on by a company using the Duro Last roof system.
    Commercial Roofing System Single-ply membrane roofing system - Duro-Last Roofing, Inc.
    I thought it was EPDM, but from reading their web site I see that it is actually a polyvinyl chloride blend. I guess that makes it a PVC roof, or is that a different product? It looks a lot like the roof in the photo. These aren't put on with heat. They use a glue, much like a swimming pool liner.
    Cary Seidner Guest
    It's really hard to tell without a close-up shot of the membrane, but in the first photo I see manufactured (as opposed to field fabricated) penetration flashing. Really looks like TPO to me. TPO, PVC and EPDM are all membranes in the "Single-Ply Roofing System" catagory, and that is what I would call it if I could not conclusively determine the type.
    Jim,
    Reading through some of those specifications, I think that might be a PVC roof system.
    At first, it looked like TPO, but reading their information, I'm thinking PVC.
    [quote=Jerry Peck;43019]EPDM is 'usually' always black.
    quote]
    Jerry, is that anything like "Jumbo Shrimp"
    That looks just like what's on my RV. RV people always just call it a rubber roof. Are the terms you guys are throwing around just more specific or is there a difference?
    The "rubber roofs" on many RVs are EPDM, while many others are TPO. You need to know which before making any repairs as the sealants are not compatible with each other.
    Larry Wilson's Avatar
    Larry Wilson Guest
    Hi guys, whichever it is, it would sure be nice to know who put it on. From the pictures it looks like they did a super job and I have a guy who is looking for someone to re-cover his industrial building. I did notice in the blown up picture on the left that there appeared to be a small cut. Did anyone else notice that?
    Larry W.
    South Carolina
    Also of note: See all those nicely flashed electrical conduits sticking vertically up with liquid tight connected to the tops of them?
    Yep, you've all seen those liquid tight fittings fail and/or the liquid tight pull out of their fittings ... what you have now is called "a rain water raceway directly down to the electrical boxes and out into the ceiling(s) below".
    Those should have (no code requirement, just common sense) had a 90 sweep on them or an LB, something to allow for the connection to be either 90 degrees to the horizontal or facing down, creating a drip loop to keep water out.
    When they have a leak, that is the first place I would check for water entry.
    Ken Bates's Avatar
    Ken Bates Guest
    I read a blurb about a recent addition to the class of white reflective, polymeric membrane claddings a few months ago. So, I think there are at least 4 being used.
    In the Boston area it's almost always Sarnafil, which actually predates EPDM by a few years. Sarna, a Swiss company has only 3 plants worldwide. The original in Switzerland, another in mainland China and a 3rd a few miles from Boston.
    Sarna embosses their trademark on the membrane (approx. 1/2 sq. ft) but it is subtle.
    Another possibility is PIB (Polyisobutylene). See Roof Choices - PIB for a brief description.
