    Default Reinspection of a deck
    This is a picture of a reinspection on a deck. All I wanted them to do was to add some joist hangers. Well they did not add the hangers but they did add a few nails!
    Ron Bibler's Avatar
    Ron Bibler Guest
    Default Re: Reinspection of a deck
    They got some nice grouping going on.
    That should count for something?
    Best
    Ron
    You know, ever since Danny Glover shot the bad guy with a Paslode, every DIY thinks he's a carpenter after spending $400.00
    In some areas a coat hanger is a nail so why shouldn't a joist hanger be a nail.
    Jeff Spencer's Avatar
    Jeff Spencer Guest
    I'd be happy to get that much.
    Any ideas for getting a builder to install deck flashing over ledger joists?
    I've inspected 14 beach houses this year. The number of flashings over the ledgers: 0
    It's gotten to where I take a drawing of proper flashing, along with pictures of rotted rim joists, sub-flooring and floor joists along to show my clients why I report them when they're missing. The best correction a builder is able to come up with is a small flashing extending about 1 inch over deck planks, and is absolutely worthless.
    Jeff
    Apr 2008
    Western Massachusetts
    Quote Originally Posted by Jeff Spencer View Post
    The FEMA Homebuilder's Guide to Coastal Construction Fact Sheet #24 is a nice three page printout you can give to builders, preferably before they install the ledger board and siding.
    It's not as if there is a great materials cost or that it takes that much longer to do it right. I installed a deck ledger once following these guidelines and it cost approximately $60 more in materials and took about an extra 15 minutes over doing it the substandard way.
    Corn Walker
    Jeff Spencer Guest
    Corn,
    That's exactly what I've been handing out/using. By their reaction, however, you would think I was asking the builder to manufacture uranium. As you say, the cost for the addition is minimal and adds years of protection.
    Jeff
    Patrick McCaffery's Avatar
    Patrick McCaffery Guest
    Corn Walker,
    Thanks for posting the FEMA link and sharing the information.
    Fuquay Varina, NC
    Don't use that thin galvanize metal that you buy at the big box stores. It needs to be hot dipped galvanized sheet metal that is much thicker or membrane and copper. The thin stuff rust in just a couple of months from the dissimilar metals.
    Mike Schulz License 393
    Affordable Home Inspections
    www.houseinspections.com
    allen elliott's Avatar
    allen elliott Guest
    Do you have pictures of the under side?
    Quote Originally Posted by allen elliott View Post
    No, I don't keep extra pictures for more than a few weeks or until I need to clear out the memory card. If it is something remarkable or unique I keep them on the backup hard drive.
