    Mike Huppi's Avatar
    Mike Huppi Guest
    Question Heating duct rusted out in slab
    I did an inspection yesterday that the lower level ducts were in the concrete slab. I smelled moisture or mildue when I entered the home so when I pulled the vent cover on two registers I found they were rusted through and there was damp rocks and dirt because the duct was rusted through along with some carpenter ants.
    Does anyone know of a repair for this or does the floor have to be jack hammered up to make new ducts
    Default Re: Heating duct rusted out in slab
    Do what I suggested years ago when I found some like that, only the ones I found were half full of water - pump them full of concrete and install new ducts overhead.
    Of the house I did, in Palm Beach (yeah, it was expensive, but it had NOT been maintained, you would think that people with money would also have common sense ... wait, why on earth would I think that ), and was two story, so it *was* a problem, but I saw no other solution. Not that big of a problem in the realm of things though, the house needed a LOT of remodeling and deferred (being nice) maintenance, so install the new ducts then.
    Steve Brooten's Avatar
    Steve Brooten Guest
    I totally agree with Jerry. Ducts set in the concrete floor are going to be a problem. If not now, later. All of them I have seen have had rust or pest problems, and needed to be replaced. Pump them full of concrete and run them somewhere else! JMHO
    Mike Huppi's Avatar
    Mike Huppi Guest
    Thanks thats basically what I told them the only problem is that it is on the bottom floor and they can not get to the joists so its going to be a ugly mess to say the least.
    Thanks for the fast reply
    Corpus Christi, TX
    Mike,
    Can you post a picture of one of the rusted through carpenter ants?
    - Paul Fix
    Mike Huppi's Avatar
    Mike Huppi Guest
    Talking Re: Heating duct rusted out in slab
    OH you vewy funny rusted carpenter ants Ha
