    Apr 2008
    McKinney Texas
    Default TXV valve mean it's a heat pump ?
    Does the presence of a Thermostatic Expansion valve indicate a system is a heat pump ? If not, when is a TXV used. Some systems have them and some do not. Not sure I understand when and why.
    Thx
    Gene
    Randy Clayton's Avatar
    Randy Clayton Guest
    Default Re: TXV valve mean it's a heat pump ?
    Gene; the presence of an expansion valve doesn't mean that system is a heat pump or not. An expansion valve regulates the flow of refrigerant flowing through the system by monturing high side and low side pressures.
    It is a great way of helping systems run at peek and efficiant capacites and is used on both heat pump and standard systems general cost of this upgrade (is not standard) is around 400.00
    Randy Clayton Guest
    It generally looks like this
    Apr 2008
    McKinney Texas
    Thanks Randy. Gene
    Could be an R410a system
