Thread: Filter Return
    Fuquay Varina, NC
    Default Filter Return
    I know this has been discussed before but I could not find it. Inspected a ranch home with a crawl space (2002). The return passes through the floor and terminates in a wall filter box. There is a conductor that runs through the box. They sniped the flashing that seals the area for the penetration through the floor for the conductor. Is this allowed?
    Mike Schulz License 393
    Affordable Home Inspections
    www.houseinspections.com
    Default Re: Filter Return
    Mike - There is an electric cable running through the return? Like Romex? I believe that's only allowed if it's in a plenum-rated conduit, or maybe if the cable itself is plenum rated, which it probably isn't.
    See: Romex Cables Routed Through Return Air Ducts - Home Inspection & Home Inspector Services For Inspections and Inspectors
    Fuquay Varina, NC
    Thanks John
