    Glen Stevenson's Avatar
    Glen Stevenson Guest
    Question extension cord or not
    Do not have a picture but will try to explain best as possible. In the kitchen
    there use to be fluorescent lighting in a tray in the ceiling hidden by
    etched plastic ceiling tiles. During the remodel they removed the fluorescent
    lights and installed a crown molding around the bottom edge of the tray. The
    question is that an outlet was installed be behind the crown molding and
    Christmas lights were plugged into the outlet. The outlet was operated by a
    regular switch. This just does not seem correct?
    Default Re: extension cord or not
    Quote Originally Posted by Glen Stevenson View Post
    The question is that an outlet was installed be behind the crown molding and Christmas lights ...
    Glen,
    No.
    Those Christmas lights are for temporary installations during the holidays, to my knowledge, they *are not* listed for 'permanent use' or installation, they are suitable only for 'temporary use'.
    From the 2008 NEC. (underlining is mine)
    - ARTICLE 590 Temporary Installations
    - - 590.1 Scope.
    - - - The provisions of this article apply to temporary electric power and lighting installations.
    - - - - 590.2 All Wiring Installations.
    - - - - - (A) Other Articles. Except as specifically modified in this article, all other requirements of this Code for permanent wiring shall apply to temporary wiring installations.
    - - - - - (B) Approval. Temporary wiring methods shall be acceptable only if approved based on the conditions of use and any special requirements of the temporary installation.
    - - - - - 590.3 Time Constraints.
    - - - - - - (B) 90 Days. Temporary electric power and lighting installations shall be permitted for a period not to exceed 90 days for holiday decorative lighting and similar purposes.
    - - - - - 590.5 Listing of Decorative Lighting.
    - - - - - - Decorative lighting used for holiday lighting and similar purposes, in accordance with 590.3(B), shall be listed.
    Glen,
    Receptacle outlet should be accessible.
    If I remember correctly, christmas lights fall under the temporary lighting category that allows a 90 day installation. Permanent lighting should be installed.
    Thank you for the responses, that is what I thought.
    Ft. Myers, FL
    Ummm Glen was it a Dome-It ceiling. Those were so cool in 1990. For those of you that dont know Glen and I drove the big brown truck in Florida together(well not together 2 trucks 2 routes.) Hey Glen whats up, getting tired of calling me for advise when I am in a bar??
    Paul Kondzich
    Ft. Myers, FL.
    John Steinke's Avatar
    John Steinke Guest
    I suspect this may also violate the 'no flex cords in drop ceilings' rule.
