    Devona Perez's Avatar
    Devona Perez Guest
    Post boewd walls in a new home
    Hi I am a new member from sunny SC in a new home that is full of bowed walls. I welcome any and all reasonable suggestions as a way to remedy this issue.
    Default Re: boewd walls in a new home
    Quote Originally Posted by Devona Perez View Post
    Welcome Devona!
    Since you say it's a new home - have you talked to the builder?
    Bowed walls usually come from framing that was wet when installed and as it dries starts to move around. Aside from cutting open sections of sheetrock to either plane down studs or replace studs there is not much you can do. Oh yeah. Big pictures work well too.
    Ron Bibler's Avatar
    Ron Bibler Guest
    DEVONA.. Now just what is any and all reasonable suggestions?
    Can we play with this ? OK I will be good. ( wellcome )
    Sometime if the framers are not crowning the wall stude the same way. this is what you get.
    You probley have one stud crowned up and the next crowned down.
    If you look at the complete building you will find this all over your home.
    Its part bad lumbber and bad instaltion.
    Best
    Ron
