    imported_John Smith's Avatar
    imported_John Smith Guest
    Default What is the "proper" terminology for this?
    Default Re: What is the "proper" terminology for this?
    Forgot the photos (argh!)
    Transformer
    Deleted Account's Avatar
    Deleted Account Guest
    Correct wiring, exterior mounted bell transformer.
    Correct terminology for the first pic would be "underexposed".
    South-West Michigan
    Post Re: What is the "proper" terminology for this?
    It appears to be a step-down transformer, most likely to 24 volts, but a label or testing would confirm that. Low-voltage wiring is OK as-is, but should probably be secured better.
    Randall Aldering GHI BAOM MSM
    Housesmithe Inspection
    www.housesmithe.com
    Fuquay Varina, NC
    Correct wiring, exterior mounted Door bell transformer.
    John you did know what it was for right? Just wanted to know the name of it?
    Mike Schulz License 393
    Affordable Home Inspections
    www.houseinspections.com
