    roger spencer's Avatar
    roger spencer Guest
    Default never seen this before
    I performed a inspection today and found that in the master bedroom and bath you could see the outline of every stud and truss in the room its almost like the furnace sooted but only stuck to these features i am wondering if this could be mold i hate to call out mold if its not so. I will try to upload some pictures
    Default Re: never seen this before
    Roger - Looks like classic "ghosting". Search the forum and the previous forum archive
    InspectionNews.com - Home Inspection Home Inspector Inspection Report
    there are many threads about this.
    Sioux City, Iowa
    Roger,
    I see this periodically. It appears to be ghosting or alson called shadowing. It can be caused from burning candles etc. Read the posts mentioned, it will give you some insight.
    Mike Tracy
    roger spencer Guest
    thank you very much after studying my pictures thats what it is and the ceiling is a cathederal ceiling with bat insulation so the top of the truss is exposed. Thanks alot just when you think you have seen it all
