    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Default Chimney questions
    Default Re: Chimney questions
    See attached for the 'preferred' method.
    Attached Files Attached Files
    Randy Brooks's Avatar
    Randy Brooks Guest
    Jeff,
    In the grand scheme of things, this is not a huge issue. Yes, brick on a 45 degree angle would be a plus, but water ultimately will enter the structure at the shoulder location eventually. Remember that the chimney crown is commonly found made of mortar as well. There are many products available in the chimney industry that will seal these mortar crowns and or shoulders and address any water sealing issues this structure may have.
