    Default How many problems can you count?
    As if the design of this isn't bad enough, it's totally rotted and there's a hot tub
    Default Re: How many problems can you count?
    Let me see, the hot tub weight plus the 8 something pounds a gallon of water plus a roof over being supported by a deck that is supported by what.
    Ahhhh, forget it. I only see one thing wrong.
    All of it
    Matt,
    My question is what's holding it up?
    Looks like a 4x4 post under the hot tub area with nothing under the stairs & open deck.
    Uhhhhhh......... that house wasn't in Milwaukie was it?
    Must smell good in that tub when the winds blowing just right.
    Michael Larson's Avatar
    Michael Larson Guest
    So where did you find the anti-gravity generators and UPS system to keep them powered up.
    Nope, it's in Aloha.... but it does kind of look Milwaukie-ish
    Yeah, the anti-gravity thing is pretty amazing. The crazy thing is that the actual workmanship was pretty good. The design was horrific but things were generally evenly built and well spaced and looked like somebody who was fairly neat and tidy... likely, drunk and stoned, too.
    Healdsburg, CA
    6.... that I can see.
    Jerry McCarthy
