Results 1 to 2 of 2
    Eric Shuman's Avatar
    Eric Shuman Guest
    Default Skylight flashing new construction
    The flashing here does not look properto me but I could not determine skylight brand to look up flshing details. It appears to me that moisture could penetrate between the metal edge at the side of the skylight and the rubbberized flashing installed. Any input?
    Thanks,
    Eric
    Default Re: Skylight flashing new construction
    Report what you see:
    I do not have the installation instructions available and therefore cannot determine if the skylight was installed as per the instructions, however I did or did not find evidence of a leak at the skylight. All roof penetrations, (plumbing vents, Attic vents, skylights, etc.) will in time leak. Skylights can also drip water, in cold or cooler weather, moisture in the house can condense on the inside of the skylight and may drip down.
