Thread: Joist question
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Joist question
    Is this type of joist rated for exterior exposure. Several joists were sistered under a hot tub and the water from the tub was deteriorating the joist. But,I was curious what everyone knows about these.
    Default Re: Joist question
    Wow, all kinds of problems there....
    Leaking tub of some type
    Boring in the lower 1/3 of the joists
    And no, I'd say that's not an 'outdoor' piece of lumber. However, I think the decking might give out before the joist.... kind of a race, really
    That's a glue-lam of sorts, definitely not intended for outdoor use... under a hot tub.
    Weyerhaeuser makes it .
    http://www.ilevel.com/literature/TJ-7000.pdf
    Also as treated / exterior applications ( PSL )
    http://www.ilevel.com/literature/TJ-7100.pdf
    David Banks's Avatar
    David Banks Guest
    Second PDF posted by Billy says PSL for exterior use.
    Rusty nails not good.
    Is deck bolted to house. Proper flashings?
    Thanks for the info. I spoke to a rep today and he said they have to be wolmanized for exterior use. Also the hole drilled is not an issue. Thanks for the web site, very helpful.
    Mat
    Healdsburg, CA
    If those drilled holes are within 2 inches of the bottom of those framing support members its a violation of IBC 2308.10.4. (2007 CBC same)
    Jerry McCarthy
    Ron Bibler's Avatar
    Ron Bibler Guest
    Good eye Jerry.
    Best
    Ron
    What if the joists are sistered, does that negate the detrimental effects of holes being drilled in the lower third.
