    Wendell Swedberg's Avatar
    Wendell Swedberg Guest
    Default Commercial Foundation vs Residential Foundation
    Would it be fair to say that the foundations for residential and commercial structures or more or less built the same assuming monolithic , slab on grade foundations. Commercial foundations are just on a large scale.
    thanks,
    W
    Default Re: Commercial Foundation vs Residential Foundation
    Quote Originally Posted by Wendell Swedberg View Post
    More or less, yes ... if you are referring to one and two story commercial buildings of similar construction (i.e., wood frame or concrete block).
    Get higher than 2-3 stories and the loads start changing, along with the types of construction and materials used.
    Kind of like old houses in what are now business areas are now "commercial" structures (no longer "residential" structures, even though they were originally constructed as such).
    Jim Zborowski's Avatar
    Jim Zborowski Guest
    Hey Jerry, don't forget the commercial ones that are now 40k sq ft homes.
