Results 1 to 3 of 3
Thread: steel I beam
    daniel nantell's Avatar
    daniel nantell Guest
    Default steel I beam
    steel I beam was prevented to turn on the back side as it was tight against foundation wall, but the visible side did not have anything to prevent it from sliding or turning. It this acceptable practice. thanks
    Mitchell Toelle's Avatar
    Mitchell Toelle Guest
    Default Re: steel I beam
    Really need a picture Daniel in order to give any feedback. You might want to review similar posts regarding connections to get an idea if what you are seeing is proper.
    MPT
    Daniel
    From what you describe it appears one end of steel I beam is braced well against overturn so it’s very doubtful the other, so called open end, could rotate off its support system. As long as it is well supported and securely attached and there is no visual evidence of any problems I wouldn't bother making recommendations for review by a SE.
