Results 1 to 27 of 27
    Default I had the granite counter top call today!
    Yep, just like clockwork! Right after the article in the ever trustworthy New York Times came out talking about granite counter tops being radioactive , the calls have started.
    The caller was checking to see if I could test the granite counter tops to see if they had any radiation. I had to stop and think, and then I told him Nope. I don't even know of any protocols for doing such a test, not to mention not having the proper equipment.
    So now that this scare is circulating has anyone given any thought as to what we as a profession might want to do to about this, if anything?
    Default Re: I had the granite counter top call today!
    Refer your clients to all the varying articles and let them make the call.
    I am sure that it will turn out to be, yep, I like my granite and at this time there is nothing definitive.
    Or just ask them if they glow when the lights are out.
    I know, what a smart arse.
    This will be the new one that lawyers will jump on the bandwagon about.
    They have backed off the mold is gold plan.
    I'm telling you now is the time to invest in Formica.
    rick
    Hey, if the realtors say its OK, thats good enough for me.
    rick
    Google Image Result for http://activerain.com/image_store/uploads/4/8/0/7/0/ar121082323307084.jpg
    Mesa AZ
    It won't be long before there is a fancy logo, on-line quiz, a new certification, and SOP for testing granite counters for radon.
    Yeah, soon they will want every home inspector licensed in turd recognition so we can tell our clients what kind of rats they have in their home.
    I'm betting that Nicky the certification king is on it already. How much you want to bet that he already has TM papers filed with the USPTO.
    Healdsburg, CA
    Hate to tell you Rick, but Formica has asbestos in it.
    Basically, we are all doomed!
    Jerry McCarthy
    Jerry Mc,
    Really? I didn't know that. I figured it had formaldehyde, but would not have thought asbestos.
    Healdsburg, CA
    What is the circumference of a moose?
    7-1/3 Meese?
    Jerry McCarthy
    Apr 2007
    gainesville fl
    Well sir,
    You need to go out a buy a few rolls of 35mm film, yes the same stuff the used to take pictures with, You will also need 2 pcs. of duct tape about an inch long and a good thick black garbage bag, and a stop watch.
    Some time at night before you go to bed you want to tape the end of the film to the counter top and then when all of the lights are out place the garbage bag over the film canister and pull out about 2 feet of film and tape that down.
    After 37.6 min. you need to wind the film back into the canister. you need to do this in 5 or 6 places in order to get a repesentitve sampling of the entire top. Then go have the film developed.
    Call me later and I can interpert your results. Now will that cash, credit card, or paypal
    Bruce,
    Back away from the bong dude.
    Apr 2007
    gainesville fl
    Just trying to be helpful to those that may have be exposed to the granite top radiation.
    Corian.
    People who buy granite would not go with Formica.
    Apr 2007
    gainesville fl
    Rick,
    Man, Daves not home.
    rick
    Google Image Result for http://activerain.com/image_store/up...2323307084.jpg
    Someone should have proof read that article - speelin' problems.
    New SoP for testing granite countertops for radon:
    Materials required: 2 pieces 6 mil plastic, one large enough to enclose the countertops from the rest of the kitchen and one large enough to enclose an similar floor area adjacent to the first enclosed area.
    2 radon monitors.
    Step One: Measure granite countertop area as floor area.
    Step Two: Enclose the granite countertop area within one plastic sheeting, lapping joints 6" and seal with duck tape inside and out if multiple pieces are required.
    Step Three: Enclose a similar floor area adjacent to the countertops with plastic sheeting, lapping and sealing as above.
    Step Four: Place a radon monitoring device in each plastic sheeting wrapped area, seal all edges of the plastic sheeting.
    Step Five: After 72 hours remove both plastic sheeting enclosures and both radon monitoring devices. If the results are displayed on the radon monitoring device, determine the difference between the granite countertop radon monitoring device and the 'control' radon monitoring device. The difference is how much radon the granite is contributing to the background level of radon.
    Use 'the difference' to scare the heck out of your clients and suggest remediation by encapsulation, and you can do that for only 100 per square foot of granite.
    I will begin issuing Certified Granite Radon Measurement Technician (CGRMT) certifications on Monday for the measly sum of $500, and, for the very reasonable sum of $2,500, I will issue Certified Granite Radon Mitigation Contractor certifications (CGRMC). Your cost can be recovered in just one job! HURRY - LOW CERTIFICATION NUMBERS - 00001 to 00050 will go first for only $500 extra. Beat the rush! Sent CASH or CHECK now!
    Once again makes me glad I am abbynormal. Richlite and Icestone countertops at home. I've never liked granite tops. Cold, hard, porous, just not appealing to me.
    Curtis Marburger's Avatar
    Curtis Marburger Guest
    Hello I am a Stone Counter top fabricator looking for some answers according to a website were i found this picture this is how you test a granite counter top.
    Can someone tell me what they are doing here ? this looks like a lot of hype to me
    Thank you
    The mad scientist at work
    The better the show. The better the profit.
    Not picking on you Radon guys.
    Have any snake oil???
    Quote Originally Posted by Curtis Marburger View Post
    Thank you
    I would say that they are either related to Rube Goldberg or they are scamming folks with a little show and tell!
    Maybe this postion statement from AARST will help.
    Attached Files Attached Files
    Colorado Springs, CO
    I'll take a stab at this.
    1 - Blank. An unexposed E-PERM SST. SST = S Chamber w/ Short-Term Electret. (I cannot see the electrets so I am assuming they are ST electrets.)
    2 - E-PERM SST measuring the radon concentration of the room air at the granite.
    3 - E-PERM SST measuring the radon concentraion of the air inside the glass jar open at one end and sealed to the granite.
    4 - E-PERM H Chamber measuring the radon flux from the granite.
    5 - Looks like a gamma detector measuring gamma radiation emanating from the granite.
    6 - Looks like a gamma detector measuring gamma radiation inside the cylinder that may be open at one end and sealed to the granite.
    Bruce Breedlove
    www.avaloninspection.com
    Personally I love granite. I am one of those older dog, in construction all my life, gotta see and feel the heft and weight kind of guys.
    I inspected a home the other day with a gorgeous granite. I have not seen one quite like it. Greens and browns and tans and grays, a slight bit of black. Absolutely gorgeous.
    I am one of those folks that when I see a beautiful old antique (not the broken down crappy things you see nowadays that the designers and weirdos rave about) I walk by it and have to feel it and study it.
    All this make believe crap you see today makes me sick. It might even look nice but most likely compressed fiber crap with a nice finish on it. The finish on it instantly tells you that you are looking at a make believe piece of crap because you would not do a finish on beautiful piece of wood like that.
    Anyway, I love granite counter tops and I for one could not be talked into removing it from my home. Like I said in another post. Guys, step outside. That radiation will eventually kill you. It gives you life and kills you at the same time. I for one would not spend my life inside even if it were to give me another several years of living. I love the sun and outdoors. Yummy, all that *pollution* (thats what you should be concerning yourself with, not your granite).
    I think the granite counter thing is absurd about the radon/radiation/gonna kill you thing. There is nothing I read anywhere that says it is going to do anything to me that regular normal living won't or does not all ready do.
    Matter a fact I am going right now to scrape some teflon off an old pan and eat it
    Just my opinion folks. Do as you may. Don't put the granite guy out of work for nothing.
    Wesley Holley's Avatar
    Wesley Holley Guest
    Fun Toys! and cheap as well.
    Now, how could excessive radiation affect a wood floor.......
    eBay – Geiger Counter, Geiger and Radiation Detection items on eBay.com. Find IT on eBay.
    Patrick McCaffery's Avatar
    Patrick McCaffery Guest
    The following is from Radalink, the maker of the Radalink telemonitor. "Radalink has received numerous calls from citizens looking for a tester who can tell them if their granite countertops are eminating dangerous radon. We refer them to our affiliate list at www.radalink.com. Consequently we have received calls from affiliates looking for a countertop testing protocol. There isn't one. However, here is what we recommend:
    Perform a typical test in the lowest level of the home suitable for occupancy.* In addition, deploy another monitor at least 20 inches above the granite countertop in the breathing zone. (Never place a test device directly on the countertop because if it is emanating radon, you'll be measuring it before it has been dilutted by the room air.)
    If the house is a slab-on-grade or crawlspace foundation, place one monitor in a bedroom away from the kitchen and the other at least 20 inches above the kitchen countertop.
    If the Rn concentrations in the room air above the countertop are not elevated, it is reasonable to conclude the countertop is not a significant contributor to the Rn levels in the home. in the breathing zone."
    Personally, I think there is a lot of hype about granite countertops and not enough scientific study.
    Paul LeRoy's Avatar
    Paul LeRoy Guest
    Is ya all fur reall?! How is sum one go na git smurt if ya ceep playin?!?! Im nue hear and triing tu lern.
    But very funny, just the same.
    Paul
    Jul 2007
    This is all a plot by Corian.
