Thread: SAFE?
    Talking SAFE?
    Lee Nettnin's Avatar
    Lee Nettnin Guest
    Smile Re: SAFE?
    Moot point, access to the lower one is a little limited. That said I would rather fall with the top one than have the top one fall on me.
    Default Re: SAFE?
    Which balcony do you think is safer, upper or lower?
    Since super powers are apparently needed to use the lower one, I'd say it's safer.
    Default Re: SAFE?
    "Stunning new condo with exceptional view has state of the art childproof balcony", Right from the brokers listing
    Default Re: SAFE?
    Now that is simple. The builder did not think the lower safe enough so he did not put a door to it. If the builder doesn't think it is safe then I certainly would not
    Default Re: SAFE?
    I betch if a kid falls while attempting to climb up or down to the lower balcony some attorney is going to use "attractive nuisance" as a basis for the lawsuit.
    Tom Phillips's Avatar
    Tom Phillips Guest
    Default Re: SAFE?
    Photoshop trick??
    Default Re: SAFE?
    Apparently a builder's goof but I've no proof?
    Default Re: SAFE?
    I would think the builder did it for no other reason than cosmetics. Consistency in appearance.
