Results 1 to 2 of 2
    Apr 2008
    McKinney Texas
    Default Can you ID this item on AC zone control ?
    I found this in the attic of a 2000 sq foot two story home with one AC unit. The house had a thermostat downstairs which controlled all HVAC function and an additional thermostat upstairs that is most likely connected to this zone control unit that I assume moves a damper to direct air upstairs. This unit had an electrical pump. First time I have run into this type of unit. I have seen many Honeywell electronic damper units but not one with a pump on it.
    Default Re: Can you ID this item on AC zone control ?
    -- I have seen many Honeywell electronic damper units but not one with a pump on it.
    Gene,
    It is an Aftermarket add on that uses compressed air to seal off / open the Zones as programed by the homeowner.
    added:
    The wire nut & electrical taped ( lamp cord ? ) is an improper connection.
