Results 1 to 13 of 13
    Default Gas and oil resistant wires
    I can't find any info on reasons for this install. Panel is a sub next to the main in the garage. any thoughs would be appreciated.
    Default Re: Gas and oil resistant wires
    Think about what the oil resistant wires supply... maybe a grease pit, pump or other equipment where oil is likely contaminant?
    Yes, That's my dilemma. None of the above. No sump no grease nunca, nada.
    What loads do the blue wires feed?
    Had some extra wire and did not feel like running to the supply house.
    Oh yeah. You really did not use the words sub when referring to any panel did you
    From what I hear around here there is no such thing as a sub panel even though I have used the term all my life.
    Were you in the navy? They have a fleet of boats which operate underwater and use those sub panel things.
    Best reason of all, and very common too.
    "Because it was on the truck."
    ""Because it was on the truck."
    I did forget that part didn't I
    "Were you in the navy?"
    No, just had a sub for dinner and It stuck in my mind
    Hmmmm ... whenever I have a sub for dinner, it gets stuck in my throat or my stomach, ... never tried sticking in through my ears.
    Cute Jerry
    Talking Re: Gas and oil resistant wires
    Yes I like the wires were on the truck, and were installed at the hoagie shop on a submarine. Thanks guys
    Chico,Ca
    A lot of THHN /THWN is also listed as MTW (Machine Tool Wire) Oil & Gasoline resistant.
    Brian Thomas's Avatar
    Brian Thomas Guest
    They have malibu lighting too. Awesome
