    daniel nantell's Avatar
    daniel nantell Guest
    Default checking air temp. for a/c operations
    When checking the air temp. on a a/c , would you get a more accurate temp. using the old bulb type themoter, or using these new type laser ones , I would think the old one measuring air temp. would be the most accurate, any feedback from the a/c men.
    Default Re: checking air temp. for a/c operations
    Use a probe type meter, not the IR. The IR will give you wrong readings. Since it is going to measure the temp of the sheetmetal or whatever instead of the air.
