    Apr 2008
    McKinney Texas
    Exclamation TEXAS HOME INSPECTORS SHOULD READ THIS
    The new TREC SOP's will be voted on in just a few days (Sept 30th). If enacted, you will be required at every house to pull a ladder out and walk on the roof, whether you need to or not, and also required to move items in the house to inspect it. See the comments below from John Cahill:
    From John.....
    "The changes are profound. Any attorney can pick em out. Read them carefully. I'll pint out the differences at www.prismrca.com over time. One example. Old SoP do not require you to move times or walk on roof. New SoP do. You must move small, light and durable personal possessions. Must access roof. John":
    -----Original Message-----
    Sent: Wednesday, September 17, 2008 6:14 AM
    To: 'John Cahill'
    Subject: RE: TREC
    John, thanks for sending this.
    Sent: Saturday, September 06, 2008 1:46 PM
    To: gene.south@tx.rr.com
    Subject: TREC
    The latest version on the TREC proposed Standards of Practice can be downloaded at www.prismrca.com.
    They were posted on September 5, 2008 and public comment will be received for 30 days. They will can then be adopted.
    The Standards are very long and have many problems. You are urged to review them and provide comment.
    Go to www.prismrca.com and download the proposed Standards.
    Your inspector associate,
    John Cahill
    Former TREC Inspector Committee member and chairman
    Richard Stanley's Avatar
    Richard Stanley Guest
    Default Re: TEXAS HOME INSPECTORS SHOULD READ THIS
    (f) Specific limitations for roof covering. The
    inspector is not required to:
    (2)inspect the roof from the roof level if, in the
    inspector’s reasonable judgment, the inspector cannot
    safely reach or stay on the roof or significant damage
    to the roof covering materials may result from walking
    on the roof;
    (B) visually inspect accessible systems or
    components from near proximity to the systems and
    components, and from the interior of the attic and
    crawl spaces; and
    (a) Definitions.
    (1) Accessible – In the reasonable judgment of the
    inspector, capable of being approached, entered, or
    viewed without (A) undue hazard to the inspector; (B)
    moving furnishings or large, heavy, or fragile objects;
    (C) using specialized tools or procedures; (D)
    disassembling items other than covers or panels
    intended to be removed for inspection; (E) damaging
    property; or (F) using a ladder for portions of the
    inspection other than the roof or attic space.
    Are these any different than what you do now?
    081808_proposed-535.227-233-new.pdf (86.5 KB, 13 views)081808_proposed-535.222.pdf (16.7 KB, 5 views)081808_proposed-535.223-new.pdf (28.8 KB, 5 views)081808_drft-REI7A-1.pdf (32.5 KB, 9 views)
    Nolan posted these for our viewing pleasure a few days ago.
